Create Docker Container Image for PostgreSQL Container Backup
  • May 3, 2022
  • 548 views
Hi Community,
I want to create a Docker Container image for backing up a PostgreSQL DB in a Container (PostgreSQL: Containerized).
I wanted to follow these instructions:
https://documentation.commvault.com/v11/essential/133162_creating_docker_container_image_for_commvault.html
Unfortunately, the option "Create a docker image" is not offered to me.
I wanted to create the custom image on a CentOS 8.1 Linux Machine.
I have downloaded the Full Media Package "11.24_Unix_AllPlatforms_11172021.zip" for the installation.
Thanks and best regards,
Andreas
Best answer by Narender
Hi Andreas
Can you please create the following file on the machine before launching installer?
/tmp/cvpkgadd_unlock_docker
touch /tmp/cvpkgadd_unlock_docker
Thank you,
Narender
Forum|alt.badge.img+2
  • May 3, 2022
Hi Andreas
Thank you,
Narender
  • May 3, 2022
Hi Narender,
thanks for you feedback!
That was the solution! I had created the file but after a reboot it was deleted and I had forgotten to re-create it. :-(
thanks and best regards
