Create VM Groups with Security Permissions per Scriptline / CLI
  • February 15, 2023
  • 70 views
Hi Everyone,
we need to create a lot of VM Groups in Commvault with different Plans and Rules (eg “Tag eq XX AND Tag eq YY”). This could be done by REST-API we noticed. But we also need to give this new VM Group a Security permissions with different Group and Role.
We did not find a scripting way to get this done adding the security permissions for a vm group.
Has someone a hint or idea where to look or has someone a “one or two liner” for this problem?
Many thanks.
Steffen
Best answer by Venu Kondabhathini
Hi Steffen,
If I understand correctly, you are looking to associate user groups / role to client group entity and assign permissions using Rest API.
Please refer to the Update security Entity Associations at:
 https://documentation.commvault.com/11.24/essential/95854_update_entity_security_associations_rest_api_post.html
Create and update roles can be found at:
https://documentation.commvault.com/11.24/essential/48689_role_operations.html
Hope this helps as a starting point.
Best Regards
Hi Steffen,
Best Regards
  • February 21, 2023
Thanks, this looks exactly what we are looking for.
