Creating Commvault HA pair using livesync
  • September 12, 2023
  • 140 views
We are trying to create Commvault HA (Active and passive node) in our lab.
We create to Commserve server in lab on the same network.
When we are trying to install Commserver Failover instance on the commserve we are facing an error. we checked log file and found - 8400 port already is in use.
and installation failed.
Please give me suggestions and or assist me about the setup.
Best answer by Javier
Hi @Surender.Singh ,
The Failover Instance in the CS should use ports 8405 and 8408, this error makes me believe the correct procedure is not being followed.
Please check the following documentation describing the whole operation;
https://documentation.commvault.com/2023e/expert/102843_getting_started_with_commserve_livesync_setup.html
If you are deploying it for the first time, you are likely to need to follow the first set of instructions “Setting up a new CommServe server with the CommServe Live Sync feature for Disaster Recovery”
  • September 13, 2023
