Cropped Window when viewing some Command Center Screens
  • January 27, 2023
  • 52 views
YYZ
Novice
Hi
Has any one seen ‘this’
Part of the left column of Command Center is obscured
The Left Column should be the name of the VM
There is no option to scroll left or right - and the left column is also obscured when the is set to Full Screen (F11)
The Browser is edge - I’m unable to test with Firefox or Chrome at this stage
Best answer by YYZ
Sebastien
You are a Magician 🔮
A click on the ‘Burger Bun’ fixed it immediately
(two Clicks bought back the CommVault Navigation pane - but also corrected the Left column of the Table - all the details now appear
Hi @YYZ ,
I am unable to reproduce the issue using Edge.
What Commvault version are you using please?
Are you able to click on the top left button?
Sebastien
YYZ
Novice
  • January 27, 2023
Hi Sebastien
It is 11.25.54 on the CommServe
It will be upgrade to 11.28 next weekend
Perfect because that’s not supported anymore and might fix the issue.
Please try to click on that icon above.
YYZ
Novice
  • January 27, 2023
Sebastien
