This just started a week or so ago. The Commserve shows libraries for a particular media agent server as “marked not ready”. Looking into the cvfwd file on both servers shows the following.
On MA:”ERROR: Connection from <commserver. to localhost:50580 is being denied due to not matching a configured whitelist and due to no services listening on this port.”
There are actually 4 error lines for each instance. “validate(), “do_connect_client90(), and two with “Client connection failed….”
In the cvfwd file on the commserve, there are similar ERROR messages.
After a minute or two, the libraries are “now marked ready” and I can see an established connection on that port (50580).
Do not see this on other MA servers.
The MA and Commserve server are in the same IP subnet.
Does not appear to be traffic related, as this will occur while nothing is going on between them.
And does not appear to be impacting functionality
Any suggestions or hints?.
Best answer by Prakash
