cvpgadd failing on Redhat9 with bash error 127
  • August 30, 2022
  • 528 views
Forum|alt.badge.img+5
Trying to run a local install on a new redhat9 system
See the following messages in sh.log
“./install: error while loading shared libraries: libpython2.7.so.1.0: … No such file or directory
Systems has libpython3 files.  Not “2”.
Running 11.24
Don’t see that listed in the system requirements for Linux.
Best answer by DavidB
@Gseibak Ok.  Turns out to be an issue with fapolicy.
The suggested fix was to run: “fapolicyd-cli -f add /opt/commvault/”
When I mentioned that to our Linux systems people.  They were not happy with having to import the entire folder with its 1000+ files.
  • August 30, 2022
Hi David,
Any security policies in place for this new server? using fapolicy ?
  • August 30, 2022
@Gseibak fapolicy is being used.  But do not see any indication of anything being blocked at this point.
I’m told that RHEL9 does not support the version 2 python libs. So am suspicious of that for now.
Just as a test. I created a symlink for libpython2.7.so.1.0 pointing at the version3 lib, and got a different response from the installer “symbol lookup error” which I sort of expected given the version difference.
But it does suggest to me that the installer is able to access the file.
  • September 13, 2022
Tried this on another system and fails at same place.  Anyone know of any issues related to Redhat 9?
Or know of a workaround for Python?
  • September 14, 2022
