Designing Commvault Backup with AVS and SRM
  • November 5, 2025
  • 39 views
Nikos.Kyrm
Forum|alt.badge.img+16
Hello Commvault community!
We are designing a backup strategy for two AVS sites, using SRM for replication and failover. We see two main approaches:
  1. Maintaining separate backup schedules and MediaAgents at each site, then manually switching backup jobs after failover and failback. This ensures data integrity and backup continuity but requires manual or scripted coordination.
  2. Replicating MediaAgents and backup disks via SRM to the DR site. This seems straightforward but Im not sure if it’s recommended by Commvault (because SRM’s block-level replication can cause metadata and deduplication mismatches, leading to backup failures or full resyncs).
Since SRM is already deployed and Commvault Auto Recovery is not an option, we lean toward the second approach. Are there other recommended practices or automation strategies for managing backup continuity in AVS + SRM environments?
Nikos
Nikos.Kyrm
  • Community All Star
  • November 10, 2025
Hi again,
I am sharing feedback from Commvault support (probably from Arlie) based on my query:
1. Maintaining Separate Backup Schedules and MediaAgents at Each Site
  • Recommended by Commvault:
    This is the standard approach for DR scenarios. Each site operates its own MediaAgents and backup storage, ensuring that backup metadata, deduplication databases (DDBs), and indexes remain consistent and isolated.
  • Failover/Failback:
    After a failover, you manually (or via automation/scripts) switch backup jobs to the DR site’s MediaAgents and storage. This avoids the risk of DDB or index corruption.
  • Pros:
    • Data integrity is maintained.
    • No risk of DDB or index mismatches.
    • Supported and documented by Commvault.
  • Cons:
    • Requires manual or scripted coordination for switching jobs after failover/failback.
2. Replicating MediaAgents and Backup Disks via SRM
  • Not Recommended by Commvault:
    Block-level replication of MediaAgent servers and backup disks (including DDBs and indexes) via SRM is not supported.
    • DDBs and indexes are sensitive to changes in disk state and server identity. Replicating these at the block level can cause metadata mismatches, corruption, or require a full DDB resync, leading to backup failures.
    • Commvault does not support or recommend using SRM to replicate backup infrastructure components.
  • Risks:
    • Backup jobs may fail after failover.
    • DDBs may require a full resync, impacting performance and data integrity.
    • Indexes may become inconsistent, affecting restore operations.
3. Automation Strategies and Best Practices
  • Automation:
    If you want to minimize manual intervention, consider scripting the failover/failback process:
    • Use Commvault’s REST API or CLI to reassign backup jobs, update storage policies, and switch MediaAgent targets after failover.
    • Automate the registration of VMs and update subclient content as needed.
  • Recommended Practice:
    • Deploy dedicated MediaAgents and storage at each site.
    • Do not replicate DDBs, indexes, or MediaAgent disks via SRM.
    • Use Commvault’s built-in DR and high availability features (e.g., CommServe LiveSync) for protecting the CommServe database, not for MediaAgent or DDB replication.
4. Commvault Auto Recovery
  • Auto Recovery:
    Commvault Auto Recovery is designed for orchestrated DR and replication of VMs and data, with built-in failover and failback automation.
    • If you require automated DR and minimal manual intervention, Auto Recovery is the preferred solution.
    • However, you stated that Auto Recovery is not an option in your environment.
  • If possible:
    Consider evaluating Auto Recovery for future deployments, as it provides robust automation and avoids the pitfalls of block-level replication of backup infrastructure.
5. Summary and Recommendation
  • Do NOT use SRM to replicate MediaAgent servers, DDBs, or backup disks.
  • Maintain separate backup infrastructure at each site.
    • After failover, manually or via automation, switch backup jobs to the DR site’s MediaAgents and storage.
  • Automate failover/failback using Commvault APIs or CLI if needed.
  • Consider Auto Recovery for future deployments if automation and seamless DR are required.
Documentation Links
I hope this will also help others in the future!
Best regards,
Nikos
