Every day, after backups, VM machines are discovered that are not used for backup and do not have agents installed. Removing them from "client compters" doesn't help. VMs have never been used for backup. I ran tests on another environment and after removing the VM this situation did not occur.
Commvault version is 11.24.90. The situation was the same before the upgrade.
Is there a way to turn off auto discovery from vcenter?
Best answer by kago
