Disk Library Maintenance - Fragmentation analysis
  • July 15, 2023
  • 254 views
Why I Can’t select Mount Paths to where I will perform a fragmentation analysis?
I Can’t check the box Analysis.
Best answer by Rajiv
Hello @Eduardo Braga
I apologize for the inconvenience caused to you. Due to the limitations of the fragmentation analysis tools, it is only possible to run the analysis against local paths on a Windows MediaAgent
https://documentation.commvault.com/2022e/expert/9345_fragmentation_analysis.html
Best,
Rajiv Singal
Rajiv
  • July 17, 2023
Best,
Rajiv Singal
