Does CV use multipart uploads to AWS Glacier - direct?
  • April 14, 2021
  • 212 views
Patrick Dijkgraaf
Certified Expert
Forum|alt.badge.img+8
Hi all!
We are troubleshooting some AWS Glacier upload performance issues and one of the questions the AWS engineer came back with is:
Do you know if they use multipart upload in their solution? That is usually the first thing to check -https://docs.aws.amazon.com/amazonglacier/latest/dev/uploading-archive-mpu.html
I did find some suggestions that we do use it:
  • Here it states that we need MultiPart permissions: https://documentation.commvault.com/commvault/v11_sp20/article?p=91277.htm
  • In previous service packs, there was an Additional Setting (nCloudMultipartSizeKB) to tune the the multipart size.
But I would like to get some hard evidence.
  1. Does Commvault use multipart uploads to AWG Glacier - direct?
  2. Can we prove that with certain log file entries?
Thanks in advance!
Best answer by Ho-chi Chen
Yes, it uses multipart upload for Glacier service. You can set CloudActivity-cvd.log(or CloudActivity.log after SP23) to debug level 2 on MediaAgent. it will log the full URL for cloud requests.
  • April 14, 2021
Patrick Dijkgraaf
Certified Expert
Thanks for confirming! I’ll look into the log setting!
Thanks, @Ho-chi Chen !
I marked his reply as the Best Answer though feel free to reply back letting me know that is premature.
