Encrypted SQL database
  • January 18, 2023
  • 1242 views
Forum|alt.badge.img+2
Is it possible to backup and restore SQL databases that are encrypted en secured?
Best answer by Scott Reynolds
Damian’s post highlights everything however I want to make a special note of the third line posted from Damian taken from BOL here
https://documentation.commvault.com/2022e/expert/18208_back_up_sql_server_data.html
The SQL agent does not backup the encryption keys. You must make sure you manage them and import them to any restore destination. DBAs should be aware but adding this for more info from MSFT here:
https://learn.microsoft.com/en-us/sql/t-sql/statements/backup-certificate-transact-sql?view=sql-server-ver16
  • January 18, 2023
Yes databases that are encrypted can be protected with the SQL iDA.
Forum|alt.badge.img+24
  • January 19, 2023
If TDE or Always Encrypted are enabled, then the following rules apply:
  •     Backups are not affected.
  •     If you have a storage policy that uses deduplication, then the deduplication ratio is low or non-existent.
  •     If the restore destination is a different client or instance, then the SQL administrator must back up the encryption key, and present it to the destination instance.
