EOL Python 2.7.x detected on commserve, is this required by commserve?
  • February 22, 2021
  • 469 views
Hi all
As title, do we need Python 2.7.x on commserve?
I found nothing in book online mention that but it seems to comes along with commserve install bundle.  I.E. I was referring to this : https://documentation.commvault.com/commvault/v11/article?p=2801.htm
This is current triggering our security sensor as Python 2.7.x is EOL
BR,
Mario
Best answer by Stuart Painter
Hi @Mario NTT there shouldn’t be any dependencies on Python 2.7, so the can be uninstalled from the Commserve.
Historically, these 3rd party packages are left in place in case customers employ these packages in their environments and auto-removing as part of service pack updates could potentially disrupt these customer created operations.
Researching this, I’ve found Commvault code was ported from Python 2.7 to Python 3 from SP11, which was quite a while ago.
If you are not using Python 2.7, please go ahead and uninstall the package.
Stuart
Hi Mario
Thanks for the question, my understanding is Python is used internally on the Commserve, so we will need to retain a version of python. Let me check internally on update options and versions to bring your installation up to date and comply with your security policy.
Stuart
Hi Mario
Please would you confirm what service/feature pack you are running on the Commserve?
Later service/feature packs - from SP11 onwards I believe - automatically install Python 3.6, but leave the previous version 2.7 installed in case of any potential dependencies.
Third Party Applications installed by Commvault Installer:
https://documentation.commvault.com/commvault/v11/article?p=121377.htm
Before you take any action I will confirm potential dependencies for Python 2.7, but once these are checked, it is likely this can be safely removed from the Commserve.
Stuart
  • February 23, 2021
Thanks Stuart for looking into this.
We’re running V11 SP20, please let me know what you can gather about Python 2.7.
Stuart
  • March 3, 2021
Thanks @Stuart Painter for sharing your research results, much appreciated!
Cookie policy
Cookie settings
