error connecting to workflow engine
  • September 1, 2023
  • 607 views
Hi Guys,
Anyone on commserve linux? Could you tell me if you are able to deploy any workflow? I am getting ‘Error connecting to workflow Engine on the console’...on cvd.log i see: “ Unable to connect to server: 0xECCC006F:{CQISocket::Connect(358)/ErrNo.111.(Connection Refused)}
Nothing recent on the WorkflowEngine.log since the installation.
Not sure if this is supported for linux commserve, though i do not see it explicitly provided in the limitations of commserve documentation.
Naresh G
  • September 1, 2023
Hi @MOGFREY,
Good day!
There is no such limitations defined for the Linux Commserve.
https://documentation.commvault.com/2023e/expert/142720_limitations_of_linux_commserve_server_01.html
Could you please let us know if the Workflow engine service is running on the Linux Commserve and is it using a PID as well?
What is the Commserver version and SQL version installed in your environment?
Could you please share the loglines from the WorkflowEngine.log and workflow.log in your environment?
Or kindly upload the cvd.log, Evmgrs.log, WorkflowEngine.log and Workflow.log to this thread.
Naresh G
  • September 1, 2023
commserve  and sql server Details
commvault status
--------------------------------- Instance001 ---------------------------------
[ General ]
 Version = 11.32.13
 Media Revision = 1191
 CommServe/Gateway Host Name = 10.148.97.82
 CommServe Client Name = kepsvpicom01
 Home Directory = /cvlt_App/hds/Base
 Log Directory = /var/log/hds1/Log_Files
 Core Directory = /cvlt_App/hds
 Temp Directory = /cvlt_App/hds/Base/Temp
 Platform Type = 7
 Cvd Port Number = 8400
[ Package ]
 1002/CVGxBase = File System Core
 1020/CVGxCommServe = CommServe
  - DB Directory = /cvlt_App/hdsDB
  - DR Directory = /cvlt_App/hdsDR
 1023/WorkFlowEngine = WorkFlow Engine
 1101/CVGxIDA = File System
 1118/CVGxGUI = CommCell Console
 1135/CVGxWebConsole = Command Center
 1158/ManagedService = Managed Service
 1173/ContentExtractor = Content Extractor
 1174/CVGxWebServer = WebServer
 1177/DiagnosticsAndUsageServer = Metrics Server
 1301/CVGxMA = MediaAgent
 1306/CVGxAnalytics = Index Store
 1602/MessageQueue = Message Queue
 1604/MongoDB = MongoDB
[ Physical Machine/Cluster Groups ]
 Name = kepsvpicom01
  - Client Hostname = 10.148.97.82
  - Job Results Directory = /cvlt_App/hdsDB/jobResults
  - Index Cache Directory = F:\Program Files\HDS\Backup and Recovery\IndexCache
[ Third Party Services ]
 MongoDB(1148718) -> 1148996
 Tomcat(1148767) -> 1148998
[ Commvault Database ]
 851/CVGxCommServeDB = Commserve Database
 852/CVGxDM2WebServicesDB = DM2 Web Service Database
 854/CVGxWorkflowEngineDB = Workflow Engine Database
 855/CVGxCVCloudDB = Commvault Cloud Database
 856/CVGxCommServeHistoryDB = History Database
 857/CVGxResourceMgrDB = Resource Manager Database
 859/CVGxCommServeCacheDB = Cache Database
 861/CVGxCommserveAppStudioDB = App Studio Database
 863/CVGxCVCloudUsageHistoryDB = CVCloud Usage History DB
[ Microsoft SQL Server ]
 Server Version = 15.0.4280.7
 Tool Version = 17.7.1.1
 MS ODBC Version = 17.7.2.1
Services
commvault list
                       *** Instance001, 10.148.97.82 ***
| Service                       |   PID   |   Description                      |
| MongoDB                       | 1148718 | Data Protection Suite MongoDB      |
| CVODS_scheduledreportingservi | 1379745 | *** Not resident ***               |
| ce_kepsvpicom01_1             |         |                                    |
| AppMgrSvc                     | 1148720 | Data Protection Suite Application  |
|                               |         | Manager                            |
| MediaManager                  | 1148722 | Data Protection Suite Media & Libr |
|                               |         | ary Manager Service                |
| QSDK                          | 1148725 | Data Protection Suite Commands Man |
|                               |         | ager                               |
| CVDotNetContainer             | 1148816 | *** Not resident ***               |
| WebServerCore                 | 1148821 | Data Protection Suite Web Server   |
| CvPreview                     | N/A     | Data Protection Suite Content Extr |
|                               |         | actor                              |
| CvMountd                      | 1148745 | Data Protection Suite Media Mount  |
|                               |         | Manager                            |
| CvMessageService              | N/A     | Data Protection Suite Messaging Qu |
|                               |         | eue                                |
| Tomcat                        | 1148767 | Data Protection Suite Tomcat       |
| cvlaunchd                     | 1148773 | Data Protection Suite Launch Daemo |
|                               |         | n                                  |
| cvd                           | 1148779 | Data Protection Suite Communicatio |
|                               |         | ns Service                         |
| cvfwd                         | 1148792 | Data Protection Suite FireWall Dae |
|                               |         | mon                                |
| ClMgrS                        | 1148799 | Data Protection Suite Client Event |
|                               |         |  Manager                           |
| EvMgrS                        | 1148804 | Data Protection Suite Server Event |
|                               |         |  Manager                           |
| JobMgr                        | 1148808 | Data Protection Suite Job Manager  |
                       *** Instance002, 10.148.97.82 ***
| cvlaunchd | 1772    | Data Protection Suite Launch Daemon                    |
| cvd       | 1773    | Data Protection Suite Communications Service           |
| cvfwd     | 1774    | Data Protection Suite FireWall Daemon                  |
| ClMgrS    | 1776    | Data Protection Suite Client Event Manager             |
  • September 1, 2023
Attached are the logs
Naresh G
  • September 2, 2023
Hi @MOGFREY,
Thank you for your cooperation.
I could see that the Workflow engine package is installed, but it does not list the workflow engine service here.
And I noticed in system requirement for workflow engine is indicating the support OS only for Windows as below,
https://documentation.commvault.com/2023e/expert/3554_workflow_system_requirements_01.html
Kindly reboot the Linux CS once and check if the Workflow engine service is up by any chance. If not, I would advise you to create a support incident with us, so that we can discuss with our Dev team and revert to you accordingly.
Naresh G
