Failed to create SQL shadow for database
  • September 12, 2022
  • 9 replies
  • 1561 views
Hi Team,
I have try to tack the backup of the SQL always on servers But backup job are failed with below error
"Failed to create SQL shadow for database"
Also we have checked with inside server there is no error messages related to VSS
Kindly help us on this issue
Best answer by Scott Reynolds
@Adarsh.op  The final check here is make sure you don't have the “Optimize for table level restore” option checked in the subclient properies.
Its is on subclient properties under the advanced options tab. Make this option is NOT checked and run a new backup. If still having issues best to open a support case there must be something enabled somewhere support can pin it down.
chrisknows
Explorer
Forum|alt.badge.img+9
You should check the status of your writers.
Ignore the fact that this is a veritas article the steps should be the same.
https://www.veritas.com/support/en_US/article.100020300
Hi @chrisknows ,
I have already checked the below  given command but there is no error,
"vssadmin list writers"
Could you please share any other solution for this issue
christopherlecky
Challenger
Forum|alt.badge.img+16
Hi @chrisknows ,
This may sound obvious but is the SQL writer there?
I have in the past listed the writers and they all show no errors, but what I didn’t realize is that the writers are missing.
Can you post the contents of the backup log for SQL?
Thanks.
Chris.
@Adarsh.op  This is a SQL AG?
Its best to leverage the SQL AG client itself
https://documentation.commvault.com/2022e/expert/18295_always_on_mssql_availability_groups.html
Also make sure you unchecked use vss option on the properties of the SQL agent under each client machine.
@Adarsh.op  This is a SQL AG? Yes
  • September 14, 2022
Hi @Scott Reynolds ,
Its best to leverage the SQL AG client itself https://documentation.commvault.com/2022e/expert/18295_always_on_mssql_availability_groups.htmlAlso make sure you unchecked use vss option on the properties of the SQL agent under each client machine. -We have already unchecked this VSS option in the each client.
Okay so do you know if you are running appaware backups or intellinsnap? This would be the only other option it would leverage VSS for the backups.
As a test you could disable the appaware option and run a backup to test backups leveraging VDI and confirm those are working. Besides that checking Windows app/sys log can also help troubleshoot the issue as vss usually logs some info in there like space issues, shadow storage limitations, etc
  • September 19, 2022
I will try all the steps you shared, But still i hva egetting same error
failed to create SQL shadow for databse
