filter Difference (exclude, except)
  • June 17, 2022
  • 776 views
What is Difference??
I don't understand even if I look at the documents
Best answer by Johannes Keil
This is really easy:
“Exclude” are files/folders that you want to exclude in your backup, i.e.: C:\OLDBACKUPS\**\*
“Except” are files and folders WITHIN those excludes, that needs to be backuped, i.e.: C:\OLDBACKUPS\Newfiles\*.*
So in this example, you will not backup anything under C:\OLDBACKUPS except from the folder “Newfiles”.
The Documentation about this topic can be found here:
https://documentation.commvault.com/11.24/expert/58503_filters.html
Johannes Keil
Forum|alt.badge.img+5
  • June 20, 2022
i got it.
I finally understood
Thank you!!
