How can I compare the parameters of storage policies, looking for an export rather than calling up the interface side by side.
  • Apr 8, 2024 10:57 PM UTC
  • 53 views
Looking for a way to extract the parameters of storage polices so we can compare the settings.
The commcell configuration report is what you are after. You should be able to use the options to filter on storage policies:
https://documentation.commvault.com/2023e/expert/commcell_configuration_report_overview.html
The CommCell Configuration Report Provides a high-level view of the settings that are configured for the CommCell, including properties, alerts, users/user groups, agents, storage policies, etc.
You can use the CommCell Configuration Report to review a wide range of CommCell contents, settings, and properties.
  • Apr 9, 2024 12:48 PM UTC
@Peterr - another option if the above is not detailed enough is to run the API’s to pull down the SP details.
Get Storage Policy Details | Commvault®
