How can we have a pop up box once we submit a SQL restore, just like how we get for an Oracle Restore
  • October 10, 2022
  • 51 views
Forum|alt.badge.img+8
Why isn't there a pop up/dialog box for SQL restores,
confirming the source and destination?
This would be really helpful to review the restore before we submit to avoid any human errors?
How shall we enable this? or request for this?
Best answer by Scott Reynolds
Hello @alligator
Are you speaking specifically in the Commcell Console or Command Center?
If Console do you leverage the Command Center for these restores at all?
If creating a case as noted above by Mike please add my name in the ticket details as we have been having some conversations about this already.
Hi @alligator , hope all is well!
I just spoke to the Associate Manager for SQL support and he suggested creating a support case to have a CMR created for this feature.
Can you share the incident number once you do so I can track it?
Hello @alligator
  • October 12, 2022
We usually use the java console way as that’s quite comfortable.
I will update the ticket# once its logged.
Thank you @Mike Struening , @Scott Reynolds
