Hi Guys,
I’ m looking how many streams are open instantly on a media agent? I have 20 MA, 7000+ servers and 17k+ daily job.
Best Regards.
The amount of streams used during operations can be adjusted at the storage policy level.
Setting the Device Streams on a Storage Policy (commvault.com)
There is also a max streams setting overall on the media agent itself ‘Maximum number of parallel data transfer operations’
Streams Overview (commvault.com)
Hi Aplynx,
Thanks for the reply. Acctually I don’ t interest which Storage Policy are opened stream on a MA instantly. When I look to Media Agent tab or Job Controller or anywhere on the CommCell Console/Admin Console I want to see how many streams are loaded on a MA instantly. Is it possible to see somewhere ?
There are 20 MAs and more than 100 Storage Policies. 10-15 Storage Policies are connected to a MA. Can't we see that in one place instead of collecting it manually via Storage Policy?
Best Regards.
Hi @0ber0n,
Media Agents don’t limit the number of streams exactly, rather the number of ‘parallel data transfer operations’. To build on that, a stream will consist of data being Read and often* data being written (I.e. Between a Client and an MA OR data moving between 2 MA’s as part of an Aux Copy).
In the case of Parallel Data Transfers, both a Read operation and Write operation are counted individually.
It is possible to view all Streams in use at a global level from the Job Controller, which is limited by the ‘High Watermark’:
https://documentation.commvault.com/commvault/v11/article?p=6352.htm
If this doesn’t answer your question, can i ask what is is you’re wanting to know and why and perhaps we can provide a more direct answer.
*I say often, as a Data Verification or browse will occupy a Reader, but no writers.
Cheers
Jase
Hi !
I was also wondering about this same..
My concern was to be aware of the current status, to assist for troubleshooting of performance, for example.
Like, can I adjust the amount of max streams for a data verification job, or an auxcopy, or schedule more, as my MA is far below the max streams..
Or to trouble shoot a Gridstor performance issue.
Or just ot confirm to my manager that the high end hardware/setup he bought is delivering max performance in line with the Commvault MA’s best recommendations :wink:
Another evolution of this kind of request, from my humble opinion, is that I would appreciate to have a report about the amount of streams (and/or jobs) per media agent for the last 24 hours, in the reports section…
Would anyone else be interested in such report ?
hi @jgeorges
I want to see how many streams are opened on 1 Media Agent on that time, live, current status.
@0ber0n , have you tried adding a filter in the job controller for that Media Agent, then looking at the section @jgeorges suggested?  That should limit your view accordingly.
Hi @Mike Struening
Yes, I tried but unfortunately it didn't work.
Best Regards.
I also tried, but the streams information is global, and does not apply to the filtered view..
Hi again,
Anyone has another suggestion ?
I strongly recommend having such a feature in an easy-to-find place in the Commvault Console for the next Service Packs :)
Best Regards.
I didn’t forget you @0ber0n !  Asking internally, will share once I get an answer (or you’ll see them post right here).
@0ber0n , heard back from development:
We show Backup active reservations and Aux reservations which is same as active streams.
Let me know if this provides what you need!
Hi Mike,
Thanks for the information, I guess this can help :)
Best Regards.
Glad to hear it!!
