How to address different storage targets for Oracke DB (commandline & DB subclients) and log backups ?
  • November 25, 2024
  • 49 views
currently I’m struggling with PLANs and Oracle Backups.
Once I associate a database subclient to a PLAN, the Archivelog storage policy is moved to the same plan. (whithout internally modifying the original PLAN association for the Archivelog subclient)
if the PLANs are using different storage targets, this is not the wanted outcome.
Is it possible to define the Archivlog policy / plan indendent to the database subclient (or even commandline) plan ? (V11.32.71)
rgds
Klaus
  • December 13, 2024
Hey ​@johanningk,
Unfortunately the Command Center does not seem to support what you want to achieve. The workaround you are using to use the CommCell console is the only option right now.
I’ll try to check internally if there is a plan to add this functionality to command center.
  • December 16, 2024
Great !
Thanks Damian
