How to compare the jobs executed against those scheduled in Commvault automatically?
  • March 11, 2022
  • 83 views
I need to make a monthly report of what was programmed against what was executed, does anyone have any idea how to obtain it?
Regards
Best answer by TDello
@JuanPa Hello,
I would like to confirm that you are looking to see what is scheduled by that has Actually run.
Can you confirm this?
To clarify what @Orazan is stating there is a job status that shows No run if a scheduled job did not run.
  • March 11, 2022
Good afternoon.  You can go into the Command Center and run a Job Summary report.  This will show you the job status on each job.  You will see some that show “No Run” or “Delayed” as well as the other more common statuses.
@JuanPa , are you referring to what was scheduled vs manually run?  The report @Orazan referred to should show the ‘Run By’.
  • March 14, 2022
I need to compare what was programmed against what was executed to get the number, I see the report that @Orazan
 mentions, but I cannot filter or make it give me unique Job IDs.
  • March 15, 2022
@JuanPa Hello,
