i have two instance 01 &02 and I want to remove these instance and create a new one but I don't know how to delete these instance
Best answer by SparshGupta
View originali have two instance 01 &02 and I want to remove these instance and create a new one but I don't know how to delete these instance
View originalHi Marwa
You can use cvpkgrm utility to delete the instances. However, please note that the backed up data might not be recoverable once the instances are deleted.
Sparsh
