I’d like to move one MA from ComCell1 to ComCell2, what is the process? After migration, may I use CommCell2 to restore file from MA which backed up three months ago?
how to move MA from ComCell1 to ComCell2?
Best answer by Mike Struening
Hi
The process to move clients from CommCell 1 to CommCell 2 is called a CommCell Migration:
https://documentation.commvault.com/11.24/expert/5078_commcell_migration_overview.html
You generally move clients, and as a result move the library access over.
Check out the doc above and see if you have any questions.
