How to troubleshoot crashing/freezing HyperScale node(s)?
  • January 12, 2021
  • 498 views
Jon Vengust
Forum|alt.badge.img+8
I’d like like some guidance regarding how to troubleshoot HyperScale nodes when they’re freezing/crashing. Is there anything I should be looking out for?
Further information or tips would be much appreciated.
Kind regards,
Jon
Best answer by Winston W
Hi Jon
Usually for issue related to HyperScale Nodes freezing or crashing, we would recommend to setup Kdump, which will allow users to capture a OS DUMP on a HyperScale Node by initiating a NMI (Non-maskable interruption) from the Server Stack
Once a OS DUMP is captured, support can assist with the review and determine a RCA for the Freeze/Crash
Here are the steps to configure Kdump
1) Please add the following lines to /etc/sysctl.conf file, this can be done using the following command:
  • # nano /etc/sysctl.conf
kernel.sysrq = 1
kernel.printk = 8
kernel.panic = 1
kernel.panic_on_oops = 1
kernel.unknown_nmi_panic = 1
kernel.panic_on_unrecovered_nmi = 1
kernel.panic_on_io_nmi = 1
Once the changes are made hit ctrl+x then Y to save your changes. Do not change the file name
2) Make the sysctl entries persistent using the following command
  • # sysctl -p /etc/sysctl.conf
3) In the file /etc/default/grub replace the existing GRUB_CMDLINE_LINUX with the following entry:
  • # nano /etc/default/grub
GRUB_CMDLINE_LINUX="crashkernel=256M selinux=0 rhgb quiet loglevel=0 rd.systemd.show_status=false udev.log_priority=3"
4) Check whether the directory /sys/firmware/efi/ exists on the server. If so it's a server with EFI otherwise it's a server with BIOS.
5) If EFI exists, regenerate GRUB configuration using the following command
  • # grub2-mkconfig -o /boot/efi/EFI/redhat/grub.cfg
If it's a server with BIOS then generate GRUB using the following command
  • # grub2-mkconfig -o /boot/grub2/grub.cfg
6) Reboot the node so that the new configuration takes effect
  • # shutdown -r now
7) Confirm the kdump service is running
  • # systemctl status kdump
We should seen an Active status of "active (exited)" if we do not, start the service using
  • #s ystemctl start kdump
8) Check /proc/cmdline after the server reboots to see if crashkernel is now set to 256M
  • # cat /proc/cmdline
9) If the server is stuck at any point later generate NMI to crash it to generate a core dump
Examples:
  • In HPE ILO
    • Information section -> Diagnostics -> Generate NMI to system button
  • In IRMC, this can be found by pressing the power button in the upper-right corner by selecting 'Pulse NMI'
Kind Regards
WW
  • January 12, 2021
Hi Jon
kernel.sysrq = 1
kernel.printk = 8
kernel.panic = 1
  • # shutdown -r now
Examples:
  • In HPE ILO
Kind Regards
WW
