- There is a data loss in customer environment.
- Customer wants me to check if there was anything which was backed up and could possible be restored.
- There are 2 incremental backups from which data needs to be restored.
- But while browsing the incremental data is stuck at “loading data….” and not actually loading data.
- Previous incremental backups are being browsed successfully.
I am not able to browse and restore data from latest incremental backup.
+7
Best answer by Collin Harper
Hello
It does look like the index is reconstructing (or attempting to) if the Browse has to load.
I am not sure why the index is being reported as outdated. By default it should backup once a week if it doesn’t meet the “ x amount of new items added to the index” threshold beforehand.
It may be best to get a case opened with Support to investigate this further.
Thank you,
Collin
