indexcache directory almost full
It doesn't clean up to the set value
so i would indexcache delete manually
how can i do?
Best answer by Aplynx
View originalindexcache directory almost full
how can i do?
View originalDeleting the index is just going to cause problems, from waiting on index restores or pending\failed jobs due to index errors.
I’d start by running the load balance workflow\report:
Thank you. I'll test it
