Hi teams,
Answer
Incremental Restore Job
I would like to know if it is possible to segment a restore job over several days ?
If yes , how to do that ?
Regards
Best answer by Sebastien Merluzzi
ok and this is File System iDA?
I am not sure how this is configured and backed up, maybe you can restore Disk per Disk, if not, Folder per Folder?
However the best would be to use Throtting:
https://documentation.commvault.com/11.24/expert/7483_limiting_bandwidth_usage_during_backups.html
Sebastien Merluzzi
