Index cash space
  • December 24, 2024
  • 271 views
Forum|alt.badge.img+2
I have an issue in Index cash directory which total size is 1.4 TB , and I noticed that the size had grown up with a high rate however that there are no additional work load added to my environment (11.36.28) and I have enabled the below parameter to be value ‘’1’’
Delete archive files of indexing backup associated with deleted backup sets
1
But the old  Legacy Index sill consume nearly more that 350 GB after running data aging job.
below is the index retention configuration that currently configured and I have configured it with below reduction days to be 8 not 14 days
Any suggestion here to keep the index directory in a healthy status using the same SSD disk space we already have without expanding the capacity as its not applicable in the current time?
 Hi Nez,
Good day!
The index cache folder will have 3 main folders
Cv_index - V1 indexing
cvidxdb & cvidxlogs - V2 indexing
The retention that you have set will only impact V1 indexing folder if its highly utilized this will save some space .
Validate the hardware requirement once and increase the space of index cache if requried
Ref : https://documentation.commvault.com/2024e/expert/system_and_hardware_requirements_indexing_version_1.html
https://documentation.commvault.com/2024e/expert/system_and_hardware_requirements_indexing_version_2.html
Regards.
Sureshkumar S
Forum|alt.badge.img+9
  • December 25, 2024
Hi ​@Nez,
As Suresh mentioned "Index Retention value" is applicable only for V1 indexing.
Also, we would like to share the below details,
From V10 we are using indexing version1. From V11 we switched to indexing version2.
V2 indexing provides improved performance and resiliency while shrinking the size of index files in the index directory and in storage.
V2 indexing works by using a persistent index database maintained at the backup set level. During subclient data protection jobs, log files are generated with all protected objects and placed into the index database.
Now we have a feature of subclient level indexing
Please refer to the below documents,
https://documentation.commvault.com/v11/expert/indexing_version_2.html
https://documentation.commvault.com/v11/expert/agents_that_use_indexing_indexing_version_1_and_indexing_version_2.html
https://documentation.commvault.com/2023e/expert/migration_of_clients_to_indexing_version_2.html
A) Regarding V1 indexing:
1) 'Index Retention Time in Days' and 'Index Cleanup Percent'.
2) Index files are kept in the index directory for a default of 15 days or until the directory disk reaches 90% disk capacity.
3) Index files are pruned from the index based on least recently accessed.
4) This means that older index files that have been more recently accessed may be kept in the directory while newer index files that have not been accessed are deleted.
B) Regarding V2 indexing:
During the index backup we have the below phases,
1) A database checkpoint
2) The database is compacted
3) The database will be backedup.
Database Checkpoint:
Checkpoints are used to indicate a point-in-time in which a database was backed up. Once the database is protected to storage, any logs that are older than the checkpoint can be deleted from the index directory location.
Database Compaction:
During data aging operations, deleted jobs are marked in the database as unrecoverable, but objects associated with the job remain in the database. The compaction operation deletes all aged objects and compacts the database.
Database Backup:
Once the checkpoint and compaction occur, the database is backed up to the primary copy location of the storage policy.
So please check the feasibility of converting the indexing version from V1 to V2.
Wasim
  • December 25, 2024
hi ​@Nez Just a additional information if the index server is associated for O365 apps or V2 indexing agents, you can monitor from command center , Manage > Infrastructure- Index servers - select the index server-- Usage tab, will show the more details and accordingly you can validate above shared sizing guidelines if cache size needs to be provisioned with more space , based on indexing or content indexing happening in your environment.
https://documentation.commvault.com/2024/essential/monitoring_index_server.html
https://documentation.commvault.com/2024/essential/data_views_for_index_servers_usage_report.html
Best Regards
Sujay kumar
