Is DPM 2012to Commvault Data Migration Possible?
Is DPM to Commvault Data Migration Possible
Best answer by Damian Andre
Yes, I believe so. DPM is listed as supported for our third-party migration tool using objectstore.
Check this out: https://documentation.commvault.com/11.24/essential/98270_migrating_dpm_data_to_objectstore.html
Basically, it creates a temporary network share (objectstore) and then restores the data from DPM into that share for ingestion. I have not done it myself, but the docs are there.
