Is it possible to enable 1Touch for all in Unix Clients at once?
  • October 21, 2024
  • 7 replies
  • 118 views
Forum|alt.badge.img+5
Hi All,
We have multiple Unix clients in a Commserve, I need to enable 1Touch for all the clients.
Is it possible to enable 1Touch for all in Unix Clients at once? Any workflow or Command/Script?
Sravan Kondeti
Best answer by Vignesh S
Hi @backup
Please find the attached custom workflow I created.
  1. Create a client group and place the Linux/Unix clients
  2. Execute the workflow by selecting the created Client Group as the input.
  3. You can verify the One-Touch option by running ‘Bare Metal Recovery’ report under ‘1-Touch Recovery Option Status by Clients’ Table. (you can download Bare Metal Recovery report from store.commvault.com if its not already imported)
A note of caution : You can test for single client and verify initially in your environment before running for Mass number of clients.
  • October 21, 2024
Script/Workflow for enabling 1-Touch for all Linux clients in a CommCell is being worked on. We will share further information when this is ready for customer consumption.
  • October 22, 2024
Thank you for the update @rcr. Any ETA for this?
  • October 22, 2024
Will share the ETA when it’s closer to a state where it can be consumed by the customers. Please be assured that we are pursuing this very actively.
Forum|alt.badge.img+2
  • October 22, 2024
Hi @backup
  • October 22, 2024
Thank you @Vignesh S .
We haven’t deployed any System Created Workflow previously, could you please help us to know how to deploy and execute it.
  • October 22, 2024
Console → Workflows → All Tasks → Import Definitions : Map the downloaded workflow file and click Import
After imported : Right Click the Workflow → All Tasks → Deploy
After Deployed : Right Click the Workflow → All Tasks → Execute
  • November 14, 2024
Hi Vignesh,
thanks for the workflow, do we have a qoperation command to do that ? if yes please provide me i found update of subclient properties which involes all the options but i need only to enable the Onetouch option.
https://documentation.commvault.com/11.20/command_line_configuration_unix_linux_file_systems_03.html#examples
Sasanka Lv
