Hi Team,
I noticed that there is a schedule to download software but it is not working to download the latest maintenance release, is it right this behaviour?
Which one of these options should be selected?
The last option if I choose, in this case,will it download just the 59 maintenance release and, for example, an future 73 not will be downloaded?
Thanks for reaching out.
You will need to check if the “System Created Download Software schedule” is configured/disabled.
https://documentation.commvault.com/2022e/expert/2705_downloading_commvault_software_using_commcell_console.html
Alternatively you can use Command Center to achieve the same
https://documentation.commvault.com/2022e/essential/120688_creating_schedule_to_download_software.html
If you’re still having issues with the schedule, please reach out to support.
Just to add, the software is conservative on grabbing the latest. There are releases marked for automatic download, and then there are releases available but will not automatically download, or will download automatically at a later date. So if you see a newer release is available and not downloaded, that is the likely reason. The documentation page shows which version is currently set for automatic download:
https://documentation.commvault.com/2022e/expert/151669_list_of_maintenance_releases_for_commvault_platform_release_2022e.html
Thank you Damian, this was exactly the answer is was given  by support.
