JAVA GUI - Home TABs
  • May 24, 2021
  • 79 views
YYZ
Challenger
Hi
In the classic console, is there a way to either
  1. Modify the Job Controller Icon, so by default it used a ‘filtered’ job controller view (without having to select the drop down on the Job Controller icon
  2. OR - Is there a way to add further icons to the ‘icon bar’ - and one of those extra Icons is a filtered view of the Job Controller
Best answer by Stuart Painter
Hi @YYZ
Thank you for the question.
You have already managed to create a filter in Job Controller.
I do not believe there is a way to customize items in the toobar ribbon, these items are visible or configured by environment settings and cannot be changed by the user.
There are a number of User Preference settings that allow you to customize how these look and feel. There are settings available for Job Controller, “Save Table Preferences” will maintain the configured list and order of visible columns, but doesn’t appear to allow for a default filter to be defined.
Stuart
Hi @YYZ
Stuart
