Javascript time calculations in custom reports aka more problems using rest api as a dataset
  • April 3, 2025
  • 57 views
christopherlecky
Challenger
Forum|alt.badge.img+20
So,
I am creating a report to capture events across time.
The problem is that the daterange input control returns time as a UTC string, but the api wants epoch time.
The input looks like this, and it passes the correct data but
I tried just sticking Date.parse in there, but it didn’t work.
Is there a way to massage the output of the controls before using them as inputs?
With sql as a data source you can handle it all the query.
Can someone tell me what I am missing?
Thanks.
Chris.
Hello ​@christopherlecky
EPOCH time is UTC just in a different format. Can we not just use EPCOCH time?
Kind regards
Albert Williams
