Library and Drive Report
  • May 4, 2021
  • 1265 views
Forum|alt.badge.img+9
Question: Is there a way to edit the Library and Drive Report to show when the space reaches below 10% in a different color other  than " Green "
REF: Library and Drive Report
Best answer by Sean Crifasi
It might be worth mentioning here that you can also configure a predefined alert to warn you when you reach those thresholds and send an email, snmp, or console alert for example.
https://documentation.commvault.com/commvault/v11/article?p=5199.htm
Insufficient storage on library
Media Management / Library Management
This alert notifies the user when there is no spare media in a library, or if the number of spare media for the scratch/cleaning pool in a library falls below the watermark.
For disk libraries, the alert is sent if the disk space falls below the watermark or if there is insufficient disk space.
  • May 4, 2021
Hello @gary mcneely,
Perhaps you could check the Disk Library Growth Report in the Web Console.
https://documentation.commvault.com/commvault/v11_sp20/article?p=38463_1.htm
If that does not fit your need you may want to open a ticket with support to ask development about a change modification request.
Sean Crifasi
  • May 4, 2021
