License usage for Client Computer Group
  • September 4, 2023
  • 88 views
Forum|alt.badge.img+13
Hi Team,
Is there way to determine to see one of our client computer group license usage on commcell console or command center ?
I checked some but didn’ t find any related. If doesnt have that would be great I think.
Best Regards.
@0ber0n
You can run the License summary report in order to see the usage:
The report can be viewed from Commcell as well as from the Command center
https://documentation.commvault.com/2023e/essential/105350_license_summary_report_01.html
  • September 6, 2023
Hi @Navneet Singh
Yes I saw this report on both site. But I cannot see  how much license capacity consumed by the specific Client Computer Group which contains clients. If I’ m wrong could you please navigate me ?
Best Regards.
@0ber0n
You need to pull the License summary report from Commcell console in CSV format and calculate the usage of the group manually. There is no report which will tell you about the each client group actually.
