Live sync Log Failover logshipping SQL error 30:436
  • 9 March 2021
  • 1925 views
Badge +14
On a fresh installed LAB, I am trying to test my failover
I have followed this r good detailed procedure.
https://documentation.commvault.com/commvault/v11/article?p=102845.htm
I got an error message in the job controller when the cv failover logshipping start.
Error Code: [30:436] Description: Instance validation failed: Insufficient SQL Server role. To configure the instance, the user must be a member of the SYSADMIN SQL server role. Source: commserve, Process: JobManager
which user should have the sysadmin rights ?
on the SQL management studio,
sqladmin_cv has sysadmin role and sqlexec_cv has only public
Thanks !
Best answer by Mike Struening RETIRED 9 March 2021, 17:05
Badge +7
Did you also check the database on the Standby CommServe?
__
Jeremy
Badge +14
Hi @Jeremy,
Yes it is exactly the same config on the standby Commserve.
Badge +14
Hi @Mike Struening,
Thanks for your help.
On the two commserves PROD and standby, the NT AUTORITY\SYSTEM has the sysadmin role
here is the exact error message.
@Bloopa is there any chance you have another account specified?
https://documentation.commvault.com/commvault/v11_sp20/article?p=18204.htm
Badge +14
Thanks to all.
On each instance I had to specify this.
