Load Balance of media agents
Forum|alt.badge.img+5
Hi just to check do our media agents have load balancing mechanism or intelligence ? Cause in a large and scalable environment , sometimes it does not make sense to manual manage in in event of failure for any MA. I know we can configure alternate path but customer is looking at more than that . They are looking at auto balance capability within MA like our VSA.
Yes, that is possible but it strongly depends on the storage backend and it depends on the event. Preferably you would use a cloud storage or CIFS/SMB target but most likely Hyperscale X will also work.
Do mind that this by default results in a HA solution for recovery tasks only. In case you want to make sure backups are also possible once one MA is down is that you will have to allow the DDB to run in degraded mode.
Speaking of true load balancing; well this is not really the case because as far I'm aware it is still the case that once a client performs its first backup than it will stick to that MediaAgent. This has to due with the fact that deduplication is partition based so it will take the shortest route to the DDB that was used for the first backup.
Onno van den Berg
Commvault Certified Expert
Forum|alt.badge.img+20
  • Commvault Certified Expert
  • 1261 replies
  • June 17, 2022
  • 17 replies
  • June 17, 2022
@Onno van den Berg , ok thanks. The backup repository will be huawei oceanprotect , hence we will offload the deduplication capabilities to the hardware. Ok in that case, will there always be issue from our technology standpoint whenever the MA is down since we dont have auto load balance capability?
Is this applicable in the alternate path configuration ? In event MA fails , another MA can take over the existing job?
https://documentation.commvault.com/11.24/expert/10842_gridstor_alternate_data_paths.html
Onno van den Berg
@lawysy please stick to Commvault deduplication and do not rely on hardware deduplication. Commvault deduplication is damm good and comes with additional advantages like reduced network traffic. but even with this in place it remains the same.
Cookie policy
Cookie settings
