Maximum size of VM, recommended for snapshot backup.
  • April 24, 2023
  • 966 views
Hi @Vikramsingh.T,
There is no maximum but in the past there was a general recommendation that VMs over the size of 2 TB use a physical agent for backup, as the hypervisor may not have kept up with VM snaps. However, its not the size of the VM is the change rate. When you make a change (write) on the system, that is what drives the snapshot size and I/O. Bigger VMs tent to attract higher change rates but that is not always the case.
Hi @Damian Andre ,
can we suggest IntelliSnap, beyond the 2 TB size? or filesystem backup should be good up to 5TB size of VM?
Onno van den Berg
Hi @Vikramsingh.T,
As far as I'm aware this is only the case on hypervisors running VMware with the default VMware snapshot mechanism in place. In case you use vVols or running NetApp + NFS + ESXi 7 update 2 or higher + with snapshot offloading, than this specific case will not be a blocker.
