Hi Commvault Community,
CommCell server is running on a virtual machine with version 11.36.28 and Windows 2016 as the operating system. Planning to perform an hardware refresh using the same network configuration (ip and hostname) into a virtual machine with Windows 2022
The documentation link:
It doesn't matter which procedure I follow—whether I import the database dump during the installation or create a new database and then import the dump using CSRecoveryAssistant.
When I finish the import and go to the CommCell properties, I see the following errors:
- In the CommCell properties, I see "Missing Packages: TaskManager.DB."
- Also, in the CommCell properties, I see Status “Unknow” in the Intalled Packages
I have created a support case with the following number “241104-493”
The support engineer informed me that the TaskManagerDB was designed for SQL performance monitoring and is no longer in use, it been removed in SP36.
The support engineer is still investigating the reason for the "Missing Package" error message.
Has anyone encountered a similar problem?
