Hi ,
i try to perform a granular restore from a MS SQL i‘ve systematicallyt his error : “Granular restore is supported for blocklevel and snap backup. database selected doesn’t qualify for SQL granular restore
i enable block-level backup ( Optimized for File system with large number of small files (Block-LevelBackup check box) in subclient.
i try with VSS and not.
i checked prerequisites and all is done.
i missed soemthing ?
thanks for help
