MS SQL Granular restore
  • January 26, 2021
  • 2213 views
Forum|alt.badge.img+8
Hi ,
i try to perform a granular restore from a MS SQL  i‘ve  systematicallyt his error : “Granular restore is supported for blocklevel and snap backup. database selected doesn’t qualify for SQL granular restore
i enable block-level backup ( Optimized for File system with large number of small files (Block-LevelBackup  check box) in subclient.
i try with VSS and not.
i checked prerequisites and all is done.
i missed soemthing ?
thanks for help
Best answer by Peter_C
Hi Virgil:
Have you reviewed and followed the doc sections for it:
https://documentation.commvault.com/commvault/v11_sp20/article?p=92238.htm
you will see:
“After you create a recovery point, you can restore the SQL tables to the same instance where the recovery point was created.”
Let me know if you have done this.
Forum|alt.badge.img+23
Hi @virgil - it sounds to me like you enabled block-level backups on the file system agent rather than the SQL agent (although happy to be wrong). Can you verify the following has been set:
  1. From the CommCell Console, click Client Computers > client > SQL Server > instance.
  2. Right-click a subclient > properties
  3. On the Advanced Options tab, select the Optimize for table level restore check box
  • Byte
  • January 27, 2021
hi Andre,
optimize for table retore is cheked ( sorry i copy/paste line from doc agent file )
Regards
  • Byte
  • February 3, 2021
Ok is done.
i reinstall SQL Agent and restart the server.
I see the table in the mount point but how to restore it in the original instance ?
i see just the proxy node in the field and is grayed out.
  • February 3, 2021
Hi Virgil:
you will see:
Cookie policy
Cookie settings
