NDMP restore with intellisnap snasphot problem
  • Sep 13, 2023 4:53 AM UTC
  • 83 views
Hello
we were doing an NDMP restore of some CIFS files.The snapshot we needed is present on commvault, visible on the array and also on NEtapp. We are restoring from vault. NDMP credentials are configured both on priamry and secondary site.
restore fails with a nonsense error:
Operation failed for path [/de04xxx022fsa01/v_c_msql_BD_PROD_VV_1/.snapshot/SP_2_3566761_348xxx_1694037804]
Please check if volume [/de04xxx022fsa01/v_c_msql_BD_PROD_VV_1] and snapshot [SP_2_3566761_348877_xxxxx37804] exist.
I can browse easily from snapshot when using recovery in commvault. Files are visible. Snapshot is healthy. Different media agents were tested. When restoring i have checked the box “restore from snapshot” but also tried without checking the box. The issue is the same. We are restoring to the same SVM /machine/ but also tried to restore onto our Media agent but it failed to.
I am wondering where is the problem. Have anybody experienced such behavior?
ThX for every hint.
Laci
Rajiv
  • Sep 13, 2023 8:40 AM UTC
Hello @LADISLAV KOREN
Please let me know if you are browsing from the correct precedence?
Best,
Rajiv Singal
What do you mean by correct precedence?
I have chosen a successfull backup and browsed from that ..all the data was visible and able to check.
L
