Netapp cloud volume on AWS
  • November 30, 2021
  • 174 views
Netapp cloud volume ontap
I am trying to find How to backup Netapp cloud volume ontap with Commvault.
Is it possible ?
I found a version for 11.23, but not 22:
https://documentation.commvault.com/11.23/essential/136726_netapp_data_protection.html
Granted, 11.24 is a long term support release, and a smarter upgrade choice in that regard :joy:
Forum|alt.badge.img+23
Hi @Bloopa !  Hope all is well!!
We have the option listed in the system requirements here:
https://documentation.commvault.com/11.25/expert/33744_system_requirements_for_netapp_storage_array.html
What are you looking for specifically?  the instructions?  Or caveats, etc.?
Let me know how I can help and we’ll get you where you need to be!
  • Byte
  • 115 replies
  • December 1, 2021
Hello @Mike Struening,
Sorry I I didn't make it clear. I was talking about Netapp cloud Volumes on AWS.
https://aws.amazon.com/fr/quickstart/architecture/netapp-ontap-cloud/
I am looking for how to backup after it is deployed by our Storage admin.
Thanks !
Thanks for clarifying!
This should cover what you’re looking for (there’s multiple options depending on your use case, but all is covered here):
https://documentation.commvault.com/11.25/essential/136726_netapp_data_protection.html
Let me know if you have any questions on the above info!
  • Byte
  • 115 replies
  • December 2, 2021
Very usefull.
Actually we use Commvault 11.22.27. Can you confirm that this version is ok ? I think that we need to update to 11.24 minimum.
Thanks again !!
Cookie policy
Cookie settings
