NetApp igroup created by commvault not delete automatically
  • August 6, 2024
  • 48 views
Hello Team
i want to know if this is a normal process when i use Intellisnap restore with NetApp
a new IGROUP created by Commvault and not getting deleted after the restore was completed
  1. this is a normal behavior ?
  2. there is an option to automatically delete the netapp igroup once the restore was completed?
Hello @Itzik Skovronek
Thanks for the details and great questions. It is normal for us to create the Indicator groups but they should be cleaned up if no longer needed after backup or restore operation.
Can you advise if there are any error messages or events in the job?
Can you advise your CV version please?
Kind regards
Albert Williams
Hi @Albert Williams there is no error. this is the reason I’m asking if it’s a normal behavior ?
CV 11.32.56
Thanks for the details. It is normal for us to create them but we should clean them up as well.
Was this a onetime event or can you recreate it consistently?
Kind regards
Albert Williams
