Network Gateways
  • December 1, 2022
  • 311 views
Hey champs,
Any one have any experience of priority between Network Gateways? There should be a setting priority=1 in FwConfig.txt
Would that work well to set in VSA servers in a VMware cluster to spans over 2 datacenters to prioritize the traffic to the closest Network Gateway where all backup infrastructure is behind those proxies?
Regards
Daniel
Best answer by Alireza B
OK just got confirmation that this feature is not yet available! It’s coming in future but for now system will just try the routes and will pick the gateway that is available in the list.
Alireza B
Forum|alt.badge.img+8
  • December 5, 2022
Hi Daniel,
Let me get some details around this priority feature for you.
In regards to VSA, please note the VSA agents works independently from Network module so you just need to make sure you have the correct firewall rules between VSA proxies and media agent etc.
I’ll get back to you for the priority feature.
Alireza B
  • December 5, 2022
  • December 7, 2022
Ok, thanks for your answer, is there any known release date?
Alireza B
  • December 7, 2022
We don’t have any ETA but I know our Engineering team is testing this internally.
