Notification if Aux Copy job fails
is it possible to get a notification if an AUX copy job fails? We had a problem with the tape library and we saw the problem a few days later.
Regards
Dennis
Best answer by dude
Here you go: https://documentation.commvault.com/2022e/expert/11511_auxiliary_copy_alerts.html
dude
Byte
  • Byte
  • 319 replies
  • March 26, 2023
Onno van den Berg
Commvault Certified Expert
In case you are using Command Center than the amount of alerts you can select are very limited, so please use the CommCell console. I truly hope the amount of alerts that can be set from Command Center is expanded soon!
Cookie policy
Cookie settings
