I have installed cloned machine (remain same IP address and same name) instead original.
On the Commvault backup server there were no changes. After the server was cloned, the backup from Commvault stopped working.
Description: Failed to start phase [Backup] on [mailserver] due to network error [Remote machine [mailserver]. The socket connect failed. Error returned [-1=Connection to mailserver:cvd(8400/8400) failed on bck: Can't unambiguously route connection to mailserver because there are multiple tunnels from different instances of CVFWD pretending to be mailserver]. Check Network Connectivity.]. Will attempt to restart. Please check if this product's services are running on the remote host.
Is there any procedure that needs to be performed on the Commvault backup server for a cloned machine?
Best regards,
Elizabeta
On cloned server with same IP can not start backup Commvault
