Openshift Servicemesh
  • May 14, 2025
  • 49 views
Hello All,
I have Red hAt Openshift KUbernetes backup. I am backing up application via label selector as the following. We noticed that There is not some application in the backup. For example ; middleware-architecture-dev. I have tried to backup this project middleware-architecture-dev with seperate subcleint. Backup completed succesfully. BU twe saw that some object are missing. This applications are Openshift Servicemesh (istio) CRD. Does COmmvault support istio objects?
Best answer by Sureshkumar S
Hi ​@ETO ,
Good day!
Openshift Servicemesh (istio) is supported from SP32
https://documentation.commvault.com/2023e/essential/system_requirements_for_kubernetes.html#istio-service-mesh-support
On the application group content try to browse the application and check if you are able to see the CRD application
Sureshkumar S
Hi ​@ETO ,
Good day!
Sureshkumar S
  • May 15, 2025
Hello ​@Sureshkumar S
THanks for answer. Yes IT seems COmmvault support it. BUt  My backup completes succesfully without error, I can not see istio apllications in the backup
Hi ​@ETO ,
Good day!
If you need further assistance its better to create a support case to check this further.
Sureshkumar S
