Oracle restore using script file
  • 1 November 2022
  • 125 views
Badge +13
Hi Team,
DB team is trying to automate in place restores for RAC server and wants to know where they can find the below parameter value to allocate channels from their end. attached script for the reference which I saved from CommVault.
it looks like 1756 & 1757 is node server value. any idea how CommVault taking this value ?
<racDataStreamAllcation>1756 4</racDataStreamAllcation>
<racDataStreamAllcation>1757 0</racDataStreamAllcation>
Script has been saved from commvault
Best answer by Gowri Shankar 2 November 2022, 17:27
Hey @Allan0105 - if this is not configurable via the GUI I don't think you can specify/override it in the save as script output. Sometimes Commvault will insert values there that are non-modifyable depending on the app.
That being said, I’m no oracle expert so let me see if I can get somebody to check this out.
Badge +13
Hi @Allan0105
Its not recommended to override the values generated via console.
The DBA could use RMAN script by following the documentation https://documentation.commvault.com/2022e/expert/21112_oracle_rac_restore_examples_using_rman_command_line_interface.html
SBT Parameters → https://documentation.commvault.com/2022e/expert/21262_oracle_rac_agent_sbt_parameters.html
Let us know in case of any other questions.
Gowri Shankar
Badge +13
Hi @Allan0105
Gowri Shankar
Thanks Gowri, i will revert back to oracle team and update
Badge +13
Hi @Allan0105
Gowri Shankar
Thanks Again Gowri, oracle team is fine with the provided info.
