PLANs and HANA databases ...
  • November 25, 2024
  • 100 views
Forum|alt.badge.img+13
when I modify the Plan for a HANA database Instance, all database’s subclients are also moved to the new PLAN.
is this the expected behaviour ?
changing the PLAN for an Instance (i.e. CommandLine subclient), I don’t want to change the PLAN for all databases in the same step.
Usually I use a base PLANs without schedules/backup frequencies, but backup destinations for the commandline subclients, while I use derived PLANs for the databases including the backup frequencies.
If I modify the destination of commandline backups, I do not automatically want to remove the existing schedules and backup destinations for all my defined databases
rgds
Klaus
Best answer by Damian Andre
It sounds like strange behavior. I’d open a support case to figure out what is going on here, I would not expect this to happen.
  • Challenger
  • December 16, 2024
Thanks Damian,
can you alos check, whether it is possible to assign the defined / associated log policy, that is assigned to the storage policy object of a plan (as possible in legacy configurations) ?
currently, once a assigning the plan to an instance, the log policy is forcibly changed to the same storage policy, ignoring any configured log policies.
This also applies to Oracle and MS SQL, which results in log backup assignments to a dedupe policyor worse, to a tape policy. (not really useable with persistent log backups)
  • January 23, 2025
Any update on this request?
Aside from use cases: wanting use a different backup target for database or log backup, also wanting a different retention set for database or log backup.
According to our best practices, we should use different plans,
https://documentation.commvault.com/2024e/expert/sap_hana_best_practices.html
Use the following guidelines when you assign a storage policies:
  • Configure the following options for the data storage policy:
    • Enable deduplication
    • Compression
  • If you are using a separate log storage policy:
    • Enable resource caching for log storage policy
    • Disable deduplication on log storage policy as logs are not deduped
Onno van den Berg
Forum|alt.badge.img+24
​@Ledoesp as customers are moving more and more to Command Center it thus means that if Command Center does not allow customers to implement Commvault own best practices then something is going wrong, right?
​@johanningk what version are you on? They have been making tons of changes over the last few platform releases, so it might be relevant.
  • January 27, 2025
I would say there is room for improvement. I have tested this in 11.36 version.
