We are trying to set up our Postgres DB to use blocklevel backups.
Our system is PostgreSQL 10.13 running on Linux RH7.
The backups run without an error. I can see all full and incremental (logs) that have been done over the last several days. After preparing the server (getting rid of the /main file and all log files) I started from the web interface a restore to current.
After about 15 seconds the Progress indicator goes from green to yellow (Shows 10% completed) and I get the the error message : Received failed message for job [258820], phase [Restore]
- Event code 19:122
After that the only thing I can do is kill the Job amd go back to my older normal backup. CommVault can restore that without a problem.
Thanks for any help!
Douglas
Best answer by DSchat
